It is currently Fri Jul 25, 2025 7:24 pm
PostPosted: Fri Apr 01, 2005 9:43 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
How thick is the burl or other woods you use for rosettes
PostPosted: Fri Apr 01, 2005 9:58 pm
mine starts out about .090 or so. Then its installed into the top proud, then sanded flush.
PostPosted: Sat Apr 02, 2005 1:56 am
Lance,
Your wood rosettes are so beautiful and clean looking!!!
Do you ever use burl wood?
Maybe burl wood is difficult to cut out?
Thanks for the pic's.
Never get tired of looking.
walter
PostPosted: Sat Apr 02, 2005 2:12 am
Walter,
I didn't find it any more difficult than any other figured wood. Just take it slow and use sharp bits.
Lance had a demo of this earlyer and I fallowed his lead.
The center of the rosette and head plate in the forground is cherry burl.
Wade
Nashua, NH
http://www.wadefx.com
PostPosted: Sat Apr 02, 2005 2:24 am
Beautiful!!!!
PostPosted: Sat Apr 02, 2005 3:07 am
I find that if you flood the burl on both sides with cyano it helps to stablize it. Set it aside and let it dry for a day. Then cut the rosette out. Good sharp down cut spiral bits work good. Beleive it or not the HSS bits are sharper than carbide.Bobc38444.5064467593
PostPosted: Sat Apr 02, 2005 3:35 am
Bob, do you sell would in the size shown above to make rosettes with?
BTW, what type of burl is that?
PostPosted: Sat Apr 02, 2005 4:14 am
Dave - go here
Bobs Rosette stock
PostPosted: Sat Apr 02, 2005 4:27 am
OOps, thanks Lance!
Guess I should have looked before I asked. Another one of those "duh" moments.
PostPosted: Sat Apr 02, 2005 6:13 am
That's red myrtle burl. I have a lot more differant woods. Just no time to put pic's up.
PostPosted: Tue Apr 05, 2005 12:12 am
Last Name: Johnson
State: CO.
Lance, how deep is your rout
PostPosted: Tue Apr 05, 2005 1:20 am
about .050 -- same as a typical shell rosette inlay.
